Luke_Miller
I read the HowTo on the procedure to flush the radiator and block. Part of it said to use tap water in the procedure. However, in reading some comments in the "Bob is the Oil Guy" forums about antifreeze, it is almost universally recommended to make your 50/50 mix with only Distalled water due to chemicals in tap water. Wouldn't flushing with tap water cause the same problem? Or am I worrying about nothing? TIA.
