Results 1 to 7 of 7
Thread: How much roughly for ball joints (don't want to replace arm)
    Jun 2006
    Toronto (Woodbridge)
    869
    Default How much roughly for ball joints (don't want to replace arm)
    I notice a lot of play on my steering wheel and I just had the alignment done two months ago. I had a tie-rod end replaced, and I was told I need a ball joint on the front passenger side. I notice the car moving a little off center either way I move the wheel and there's a little too much play.
    Is it just hte ball joint? What am I looking at for parts and labour?
    2002 Volvo S40 1.9T
    1998 Mercury Mystique LS (Written Off)
    Jun 2005
    Virginia, USA
    11,070
    Jack up the car and push and pull on the lower control arm at the ball joint. If it is that severe that you can feel it on the steering wheel, it should be very obvious when you push/pull when it is up on jack stands. It costs about $50 for the ball joint and about $50 to $75 for labor to replace it.
    "Entiendo un poco espaņol"
    Quote Originally Posted by Tony2005 View Post
    Actually they are 19.50 from BAT each. I don't think that there is much difference in price going to the dealer either. These are the bolt on ones.
    Jun 2006
    Ohio and Melbourne, Florida
    188
    Default ball joint
    Mine were $32.76 each with a lifetime warranty.
    Jun 2006
    869
    Tony, do you think that accounts for the major 'play' in the steering wheel? I mean holding it straight won't happen and it shakes and vibrates, is that a sign of things to come? I'm getting it checked out for sure tomorrow, but I know little to nothing in terms of this car's suspension parts and I want to make sure these guys aren't just going to take money that I so sorely need for my school...
    ANyways, just in a nutshell, is that it causing the play in the wheel? Or could it be something else all together?
    2002 Volvo S40 1.9T
    Jun 2006
    Center City, MN
    2,796
    they are 30$ after tax at any auto parts store. if you have a good set of drill bits you can jack up the front of your car (high as possible) and drill out the rivet welds, and the new balljoint just bolts on. you will need a balljoint spreader (me and CSVT#49 used 2 spreaders stacked on top of eachother and it works slick) and proper hand tools. it woudl probably be easier to just pay a shop to put them in, but that's about as expensive as the whole arm.
    98 CSVT-black. on it's second 3L swap. 219hp/211 trq
    Jun 2005
    Virginia, USA
    11,070
    Quote Originally Posted by m4gician View Post
    As posted earlier, jack it up, push/pull on the ball joint. You will know right away if the ball joint is broken as it will have a lot of free play in the "cup" if broken or close to.
