Page 1 of 2
1 2 LastLast
Results 1 to 10 of 20
Thread: headlight resoration
    Default headlight resoration
    I want to give this a shot, I read a howto on VWvortex that is proven to work extremely well. I was going through the list of things I need, and one thing is 2000 grit sandpaper. Where in the hell can I find this stuff? I have been everywhere and the highest I can find (which I own) is 600 grit, which is the first step in the process. But I need the 2000 to make the surface smooth and clear. I tried Menards, Home Depot, Autozone, Sears, none of them carry it. Where in the hell can I find it?
    I can get 1000 grit, but I dont know if thats good enough.
    Gone.
    Sears, HD, etc won't have it from what I've seen. It will have to be auto-parts related. Call around to some local body shops to see if they have any ideas. Heck maybe they could even "spare a square" (from Seinfeld).
    You could use just the 1000, but you'll have to polish it much more, because the grooves left over will be so much deeper. I did 1500-2000-2500 and the polishing was easy.
    2004 Azure Blue Mustang Mach 1
    1992 Calypso Green Mustang LX 5.0 Sold
    2000 T-Red SVTC #2010 Sold
    Aug 2004
    waiting to get banned
    8,480
    No results found for resoration.
    Did you mean res oration (in dictionary) or Restoration (in encyclopedia)?
    11 second daily driven Evo VIII
    Mountaineer- Winter beater
    Used to own- First NPG Turbo'd SVT
    missed the t
    Gone.
    If you do it right, it works! I wasn't too sure about it at first, but did exactly as the headlight how-to said and this is how mine worked out.
    The headlight on the left in the pic above and the pic below are what both headlights looked like when I first got them.
    After headlight restoration below.
    99 T-Red CSVT #2300
    94 Cobra 5.0-Sold
    99 Black CSVT #2200-Sold...
    http://www.cardomain.com/ride/2528810
    Napa has 2000 grit sandpaper...Ive done this to both the Mystique and the Contour. Worked very well.
    1999 Contour SE 2.5 mtx 192,XXX good runner
    i picked mine up at autozone, try calling around to different ones in your area.
    *TROLL!*
    Lexus is300
    -Rims, Nav, Tint, Bump in the trunk, hunting for some boost.
    Oct 2005
    Toledo
    1,188
    I used 600 then 1000 then buffed it with Meguire's PlastX. Smooth as glass
    TRed CSVT on FSVTs.. in pieces for now!
    http://www.cardomain.com/ride/2154233
  9. #9
    Jul 2006
    Newport News, VA
    1,149
    I actually got a kit from Firestone that had everything in the box. Gloves, sandpaper, cleaner, polish, and some other crap. It was about $35. It actually worked pretty well, but i'm sure the sanding process works just as well. Many of the auto repair stores offer this service now. You can either pay them $100 to do it or just buy the kit like i did.
    98.5 CSVT #5612 of 6535
    http://www.cardomain.com/ride/2056366
    R.I.P 91 Escort GT
    http://www.cardomain.com/ride/222379
    "Opinions are like butt holes.......Everyone has them.......some just stink more than others"
  10. #10
    I did it the other day with 600 and 1000 grit, then used a headlight restorer I got from Autozone, then Meguiars PlasticX. Looks a HELL of a lot better
    I used Liquid Dawn mixed with water as my wet base for the sand paper, I watched the water turn yellow headlight looks a million times better now. I have to do the driver side one today as its starting to haze a little.
    Gone.
