whats with this seafoam and or berrymans, whats it do? clean the motor up? were do i buy it and how to use it. thanks
-JON 99 CSVT T-Red. #2437
www.myspace.com/ripscottfrost
or is this it? haha should have seached first.
http://members.nuvox.net/~on.roz/cars/z28/seafoam.html
You can use either one. They are available at Wal-Mart or most auto parts stores. You can use it in your oil, suck it into a vac line, or in the gas tank.
1998 #5979 SF/MNB
2000 #0801 B/T
BUY MY STUFF IN THE CLASSIFIEDS!!!!!
thanks sorry i i reaized i should have googled first
You suck Seafoam through the intake ports on the top of the UIM.
Basically it just cleans most of the carbon buildup out of the engine. You will probably notice a small gain.
230.2 WHP @ 6500
237.0 WTR @ 2250
99 Tropic Green SVT
Hi Guys,
I want to seaform the engine. Which vacuum line do I disconnect and where is this vacuum line located?
Thank you,
Derek
1999 Ford Contour SE (Black)
S&B Powerstack Air Filter
Brullen Cat-Back Exhaust System (Loud Setup)
Sylvania SilverStar Headlight Bulbs
MSN Messenger: ddasilva99@hotmail.com
the 2 on the top of the intake manifold. they are right behind the throttle body. you remove those and put a tube in the holes. one at a time.
Go to the Duratec Maintenance forum, and read the "read me first" thread for a "UIM/LIM cleaning via vacuum" how-to. Imagine that.. a how-to for Maintenance on the UIM of your Duratec in the Duratec Maintenance How-to thread.
Question re: the SeaFoam in the vacuum lines.
Do you turn off your car before switching vacuum lines? The FAQ isn't clear on that part.
