Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 22
Thread: I need to quiet down this exhaust...
    Dec 2001
    Petoskey, Michigan
    3,945
    Default I need to quiet down this exhaust...
    I'm running Weapon R headers, BAT y-pipe w/ high-flow cat, and SVT cat-back with a Magnaflow resonator. Its too loud. Do you guys think a TruBendz resonated magnaflow cat-back would help quiet it down or make it even worse? Maybe I could try using the weapon R y-pipe instead of the BAT?
    1996 Ford Contour SE 3L MTX - RIP
    Ford Racing . Fidanza . Quaife . WeaponR . TruBendz
    Driven.
    May 2000
    Grand Rapids, MI
    26,864
    Blog Entries
    1
    [Arnold]Stop being a pu$$y![/Arnold]
    Dec 2001
    Petoskey, Michigan
    3,945
    bring in THE EXHAUST TERMINATOR
    Driven.
    May 2003
    Ocala, FL
    6,295
    So you still have the stock SVT mufflers, a res., and a cat? I dont think you could make it much quieter without hurting performance (i.e. adding baffled mufflers, putting the stock manifolds back on, etc.).
    If it drones, you could try a longer res. maybe
    #4559 of 6535 Black 1998.5 CSVT Troll 3/10/07
    2008 Honda Civic Si
    - B&G/Ingalls/SPC/Corsport/Eibach/Hybrid Racing/Skunk 2/AEM/Vibrant/Xenon Depot
    Dec 2001
    Petoskey, Michigan
    3,945
    Quote Originally Posted by KingpinSVT View Post
    stock SVT mufflers, but there's a magnaflow res in place of the stock resonator, and the high-flow cat that comes with the BAT y-pipe is installed.
    I found the single exhaust item that added the most sound was the BAT y-pipe with high-flow cat. Is there a chance the Weapon R y-pipe with a different high-flow cat could be quieter?
    I can deal. Its just that the Nissan 350z I drove over the weekend had such a nice mellow tone and I kind of liked it
    Driven.
    Quote Originally Posted by rkneeshaw View Post
    [Arnold] I AM THE EXHAUSTINATOR! RWAARRRRRRR [/arnold]
    It really wasnt that loud when I drove past you on the freeway...
    Gone.
    May 2004
    Calgary, Alberta, Canada
    4,506
    Thats not loud enough.. Stock 350Z sounds nice.. but too quiet..
    Adding the trubendz kit will make your car louder.
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
    May 2003
    Ocala, FL
    6,295
    Thats what I meant.
    Youre ears must be sensitive (nice way of saying your a puss! LOL). Does a high flow cat add that much noise? I would expect it to be about the same. I reckon must of the noise you are noticing is coming from the thinner metal of the headers and lack of precats. Other than that, I bet you cant get much more toned down unless you plan on putting the stock manifolds back on.
    But my question remains: is it drone you are complaining about or loudness while on the throttle? If its drone, a larger res. may cure your problems (loud at cruise). If its overall tone, like I said, there isnt much you can do without going backwards. Baffled mufflers may help, or a baffled res., but then you would be backwards modding.
    I consider my exhaust setup to be fairly loud (MSDS, stock cat, magnaflow res and race series mufflers. All straight through). It is damn near silent while cruising (no drone) because I have a large enough res.
    You may just have to deal with it!
    2008 Honda Civic Si
  9. #9
    Dec 2001
    Petoskey, Michigan
    3,945
    Yup, sorry, its mostly drone. When the RPM's are like 2.5k -4k at constant throttle. People in the back seat complain a lot, and well, I can still hear them complain. at idle she sounds really cool
    Driven.
  10. #10
    May 2003
    Ocala, FL
    6,295
    How long is your res? Or do you have the part number?
    2008 Honda Civic Si
