Page 1 of 2
1 2 LastLast
Results 1 to 10 of 13
Thread: Cheap n Easy Mods to improve fuel economy?
    Jun 2006
    Toronto (Woodbridge)
    822
    Default Cheap n Easy Mods to improve fuel economy?
    Well...
    Here's what I have so far...
    Run Berrymans or Seafoam,
    Change plugs,
    Change air filter (replace with K&N or clean open air intake)
    Fill tires to maximum pressure (debateable, if tire says 44psi then I put 44psi)
    Remove resonator - replace with 4inch magnaflow or similar
    Optimize TB,
    LOWER THE WEIGHT OF THE CAR (i.e. empty trunk, don't car pool fat people, etc.) lol
    Keep windows closed on highways,
    This might be not as cheap...
    Rebuild UIM/LIM using FAQ on site,
    Add a bolt on exhaust,
    2002 Volvo S40 1.9T
    1998 Mercury Mystique LS (Written Off)
    Sep 2002
    St. Louis, MO
    2,890
    Forget the idea of "mods".
    Do you maintenance. Keep the vehicle tuned and maintained. Do not over-inflate the tires, use the recommended pressures on your vehicle's data sticker.
    "Modify" your driving habits instead. Avoid rapid starts and stops. Conserve motion (kinetic energy). Lower your driving speed.
    In case you have noticed, fuel prices have dropped by nearly 40% since just two months ago. Surprising you weren't more interested in economy when the prices were peaking.
    If you think about it, you'd have a really long payback period for most of those "mods" even at $3/gallon.
    Steve
    Retired 98 Contour SE Sport 2.5 Duratec ATX - Dead transmission @ 235K miles
    2001 F250 Super Duty 6.8L 4x4 - The NEW Workhorse 152K.
    2007 Mariner 3.0L AWD - Wifey's new ride
    2000 Contour V6 ATX Acquired 11/1/2013
    Jun 2006
    822
    So even if my tires say 44psi I should go by what the sticker says? Who should I believe, the sticker or my tires (replaced the stocks with better tires)?
    2002 Volvo S40 1.9T
    Dec 2001
    Gales Ferry, CT
    24,978
    Blog Entries
    93
    Quote Originally Posted by m4gician View Post
    most likely that is the max psi for the tire that is on the tire, go with what the stock sticker says, personally I run one pound higher on stock size tires then the sticker says
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 99 Contour SE Sport <- traded in 2/13
    - 2k Contour SVT - #2137
    May 2005
    Pittsburgh, Pa
    2,168
    optimizing the TB wouldnt help with fuel economy. it may increase HP but if you think about it, when the throttle is only partially open (during economical driving), there would be no benifit from the optimization because of the angle of the plate(dont know the technical name). so while an optimized TB may increase HP at WOT, it wont have more power during "economical" driving.
    ~Ryan
    2012 Subaru WRX
    1999 T-Red SVT Contour #1701 / 2760
    OZ Ultraleggera 17's, BAT Kit, MSDS, BAT High Flow Cat & Y-pipe, B&M Short Throw, Taylor Thundervolts, Green filter, Pudmunkie heat shield
    Jan 2006
    Montreal
    1,059
    I've heard you get better fuel economy with the tires inflated more. I was reading somewhere to go to the max of the tire for max fuel economy. There is a "correct" tire pressure which will maximise the life of the rubber, if you overinflate you will wear the middle of the tread prematurely, and if you underinflate you will wear the edges (thanks Auto-X-Fil). Depends on tyre, car, driving style and whatever so you need to experiment.
    00 Silver Frost SVTC #1429/2150: Born 10 Jan, 2000
    3.0L, Spec Stage 3 Clutch, LSD, Koni Sport Kit +more
    Aug 2000
    SF Bay Area, California
    142
    Quote Originally Posted by SVTC1136 View Post
    Don't inflate your tires to the max. That doesn't make any sense.
    You may be saving gas, but its dangerous and you will also be wasting more money for tires.
    My suggestion is to learn how to drive conservatively (this can really add a lot to your MPG - don't brake uneccessarily, don't accelerate too hard, coast in gear to conserve kinetic energy, learn how to time stop lights so you can avoid coming to a complete stop before a stoplight, etc).
    For city driving 33-34 psi should be fine. If you do a lot of highway driving 35-36 psi could be ok. But that should plenty. Be safe!
    SOLD
    1998 E0 Ford Contour SVT - DOB 8/19/97 - #3101/6535
    Silver Frost/Midnight Blue
    Jan 2006
    Montreal
    1,059
    Quote Originally Posted by vcontoursvt View Post
    Note I went on to say there is a correct tire pressure??? I agree that if you overinflate the tires they'll get premature wear which will offset any gas savings. As for dangerous????, if the tire manufacturer says its OK, I'd tend to accept their advice.
  9. #9
    Sep 2002
    St. Louis, MO
    2,890
    The tire manufacturer has to cover their behind so that overinflated tires don't fail/
    The vehicle manufactuere has to cover its behind because over-inflated tires will often negatively affect the vehicle's safety as to handling and stopping.
    Gross over-inflation of a tire beyond the vehicles specification is just a bad idea.
    Steve
  10. #10
    Oct 2006
    Yorktown, Va
    19
    Don't know if this helps but here's what the National Highway Traffic Saftey Administration website has to say...
    "Tires are manufactured for many different vehicle makes and models of vehicles. And the psi number on the side of a tire only reflects the “maximum permissible” inflation pressure for that tire — not necessarily the correct psi for your vehicle. When filling your tires, always follow your vehicle manufacturer’s psi recommendations. You’ll find this psi number on your vehicle’s tire information label, as well as in your vehicle owner’s manual."
    For more info here's their URL http://safercar.gov/Tires/pages/TirePressureFAQ.htm
Page 1 of 2
1 2 LastLast
