Are there any how-tos or anything about taking off the black trim peice that goes around the headlight switch and the radio/hvac controls. reason i ask is im gonna be painting my dash peices soon.
2001 Ford SVT F150 Lightning Black
1998 Ford SVT Contour Silver Frost E0 #3455/6535 *sold*
*lots of contour parts for sale please PM me*
http://www.contour.org/ceg-vb/showthread.php?t=31994
IIRC, its 2 screws under the headlight switch/mirror control. Then it pulls out with a little force because its clipped in at the top(best way is remove the cover under the steering wheel so you can see the clips from behind and get an idea).....
for the radio/hvac its like 4 screws to up front and 2 in the back harder to screw out get a short screw driver, then you basically look at it from the front and pull it towards you.
I doubt there is a how-to on it cause its real easy??!!!
- Amyn
99 (No Paint, No Powertrain, No Doors, No Trunk) CSVT - 0532
Koni/GC's - 18" @ 15.2lbs - BAT 21mm RSB(Reinforced) - OMP/Rawburt STB - MSDS Headers to Bassani Catback - Ford Racing Wires - CF Trunk - Parkedcar Stamped - Samco Hosed - Baer BBK - 3L Turbo
- 95 Mystique LS <- For Sale
- 99 Contour SE Sport
- 2k Contour SVT - #2137
Aircougar Performance
yeah i did this and all the cheap clips broke off
i'd recommend you do the trim around your guages too. it'll look alot cleaner. i'd also recommend you go to a junkyard, get an extra set of trim pieces (mine only cost me $18 for the whole set) and paint those because odds are you wont get the paint to look right on the first try and you dont want to have your whole dash hanging out for days. heres a pic of what mine looks like. i just finished it up about a month ago
good luck!
its not that hard to take out. just be gentle
98 CSVT T-Red
Vortech, euro MTX75, Torsen, Sachs etc.........
2003 SVT Lightning Sonic Blue
North Carolina Air National Guard. Air Traffic Control
you've gotta hold your bezel like you would a woman.
98 SVT E0 Black/MNB #1756
98 SVT E1 Silfro/MNB #4852
i thought it was funny
98 CSVT T-Red
