installing foglights on a 97 contour GL that was not originally equipped with them. Got the factory fogs from BAT. The connectors for the lights were stowed up in the valance so I thought I was good to go. Fabricated brackets and installed the fogs. installed a factory headlight switch with foglamp option. Fogs didn't work. Checked fuse in engine bay fuse box there is a good 15A fuse installed. Checking for relay and I cant find it or a harness for it. pulled the headlight switch panel and the panel below it and there is no foglight relay in there. I have Chiltons and Haynes manuals and neither one shows the foglight relay on any schematic. Haynes says its located at interface module bracket. Any where else this harness could be stowed or am I just missing a harness? Any suggestions? Thinking about running power through the factory switch straight to the fogs, but the schematics I have are obviously incorrect. I need to figure out the easiest way to get power to the harness I do have.
