Results 1 to 8 of 8
Thread: Ordered wiring harness today
    Jul 2003
    Graham, TX: a place so nice, they rob your house twice! & Houma, LA
    3,194
    Default Ordered wiring harness today
    As it says, I just ordered 1 of the wiring harnesses today. It should be here in the morning. Hopefully I'll have it wired up in the next couple of days. I would like to see this thing fire up by the weekend. Talked the local dealer down from $175 to $150 plus tax. Could have gotten it from Bill for $140, plus shipping. This way I get it for roughly the same amount, and get it the next day!
    Also picked up a set of brand new B&G springs from ohsigmachi this weekend for a c-note. I probably won't put those on until after I've swapped out the rear disc brakes from my parts car.
    If home is where the heart is, then I'm out of place.
    Quote Originally Posted by m!key
    IRingTwyce for president!
    Quote Originally Posted by ChattavegasSE
    I second the motion for IRingTwice for prez!
    Sep 2004
    Tampa, FL
    1,976
    Sweet man, good luck and take your time.
    I got pics of random parts/connectors if you need them and I'm always ready to help.
    '95 Contour GL, Zetec, Teal, ATX
    Born on Sep. 4, 1995
    100k+ miles!
    Jul 2003
    3,194
    Thanks for the offer! I'll keep you posted on the progress.
    Jul 2003
    3,194
    Dammit! Three connectors on two of the harnesses are different than what is on the car! Now I have to start soldering.
    Jul 2003
    3,194
    Exclamation HELP HELP HELP with wiring!!!
    OK. *sigh* I have the harness all wired up and in place. However, the car does the exact same thing it did before I started all this. It turns over, but no apparent spark, and the fuel pump isn't priming/working. I've checked all my connections, fuses and relays are good, fuel pump has been checked and works. Any suggestions?
    Sep 2004
    Tampa, FL
    1,976
    Sorry man, I'm stumped. Maybe you have a bad coil pack. I can't think of anything else that is wrong unless something is clogged. Hopefully some one else will chime in.
    100k+ miles!
    Jul 2003
    3,194
    Quote Originally Posted by KerryKool View Post
    You have a PM.
    Jul 2001
    Puyallup, WA
    690
    John,
    Did you check spark plugs (gap and fouling) and wires (cracked, boots, connections to plug and coil)? Check all the terminals on the coil pack, they can get corroded and cause misfires (although unlikely in Texas). I personally haven't done it but there is a way to pulse the injectors to make sure they are in working order.
    Ohsigmachi
    Old ride: '96 GL MTX Zetec **sold after ten years of ultra-relible service.**
    Newest Ride: 2003 Jaguar S-type R = Superchraged Luxo-rocket
    --I don't want to hurt you, but it's still on my to do list.--
