Results 1 to 6 of 6
Thread: A/V cable
  1. Default A/V cable
    When I think of an RCA cable, I picture 2 wires: one labeled with red and the other labeled either white or black, each wire having some type of connector attached to the ends.
    I have the parts to make my own RCA male to RCA female cable.
    I will use these on one end:
    and these on the other:
    with 12-guage speaker wire.
    Im just learing how to work with electronics/audio, so Im not sure how to solder this together. Only 1 wire is going to each connector, but each connector has 2 solder points?
    Can someone please explain what I need to do?
    thanks,
    mzracer360
    2007 Toyota Corolla S
    1995 Ford Contour GL - Sold 8/23/08 for $800
    The center "pin" conductor will be your video output.
    the outer "ring" of the RCA connecter will be a ground. The cable you are using should be a shielded two conductor cable, not a single wire.
    .99 Silverfrost
    Call me for free, if you need any help or anything.
    |_|0|_|
    |_|_|0|
    |0|0|0|
    Jan 2002
    Grand Blanc, MI
    3,486
    the owner of Knukoncepts is a member on this site. How much money do you expect to save by building your own? His prices and quality are awesome.
    http://www.knukonceptz.com/productMa...0Interconnects
    2000 SVT Black/Tan #1163/2150 SOLD
    2008 Grand Prix GXP
    2009 Saturn Vue Redline V6 AWD.
    12 gauge is way to large for RCA connections, the largest you would want is 18 gauge. With RCA signal, their is such thing as too large of conductor.
  5. Default
    Quote Originally Posted by KnuKonceptz View Post
    Agreed I wouldnt go above an 18 gauge
    99' Contour SE *100,000 Sept 12, 2006*
    Totaled *October 20th, 2006*
  6. Default
    Quote Originally Posted by CarpePoon View Post
    the owner of Knukoncepts is a member on this site. How much money do you expect to save by building your own? His prices and quality are awesome. http://www.knukonceptz.com/productMa...0Interconnects
    Im not trying to save money. I need an A/V cable to go from the back of my headunit and through my center console to wherever I decide to put it. Thats why I choose these for one end:
    I did not know that, Im gunna go get some of that gauge then!!!
