Results 1 to 6 of 6
Thread: Gauge Install
    Aug 2004
    Renton, WA
    1,656
    Default Gauge Install
    Hey everyone, i recently got in on the Lotek GB and I am looking for a reputable shop to install my gauges. I just dont trust myself with this one. Anyway if anyone knows of a good shop around the area let me know. Thanks.
    -tropictour
    2000 Contour SVT
    Tropic Green
    SHO Shop CAI, BAT Pipe, PS/Alt. UDP's
    Bassani, WR Headers/Y-pipe
    Full HMS Trans./Fidanza Flywheel/SPEC Stg. 1
    It's not a bad install. What gauges are you hooking up?
    Derek
    Audi TT Coupe
    Subaru Outback
    Scion xB - SOLD
    2000 SVT Contour - SOLD Miss That Sound
    Please share the road with cyclists.
    Aug 2004
    Renton, WA
    1,656
    Oil Pressure (electrical)
    Fuel Pressure (elec.)
    Air/Fuel
    All SW Max Perf. gauges.
    -tropictour
    2000 Contour SVT
    Tropic Green
    On this subject, has anyone mounted gauges above the lighter and bin that sit beyond the cupholders (and under and behind the radio) at the front of the console? I find I can see that location easily from the dash, and it would keep the gauges out of the way. What's more, its a nice, flat panel.
    2000 Tropic Green Contour SVT
    1994 Opal Frost Taurus SHO -- SOLD!
    "Have you ever seen a spleen that large?"
    "No -- no -- not since breakfast."
    Sep 2006
    Portland, Orygun
    1,393
    I havn't seen that but there is limited room between the face you are looking at and the vent duct behind that area. I had a great plan for adding power ports there that fizzled as soon as I got a good look there. Now guages may work with an extention bezel......
    Proud Dad of a US Marine
    99 Contour SE Sport / V6 MTX
    95 Contour GL / 4banger ATX - Like no other.
    "its not shot it just grinds a little when going into third" - tjzollman 2/25/08
    Try to be as good a person, as your dog thinks you are....
    I had the (blinky light) A/F gauge, electrical oil temp and electrical oil pressure. I tapped into the firewall-side cylinder head (not the most accurate for pressure, but I wasn't willing to play with the alternator to tap for pressure). I "teed" that tap for the oil temp. A/F was taken from the front cylinder bank.
    IIRC, the install took me 3 or 4 hours from start to finish. Perhaps a little more w/ all the wiring. I also painted my pod prior to the install.
    Laura - I've seen installs of gauges in that coin holder. Lots of people put their boost gauge there.
    Derek
    Audi TT Coupe
    Subaru Outback
    Scion xB - SOLD
