Need More Help...
Need More Help...
So there are two problems that may or may not be related:
1) Car will start but the engine will keep running when the key is turned off. I have to remove the fuse to the fuel pump to stop the engine. Then put the fuse back in to restart.
2)There is a buzzing sound coming from the power distribution box under the hood. When fuses 1, 2, & 3 are wiggled there's a clicking noise and the buzzing stops temporarally. Anything can retrigger this problem.
The ignition switch itself has been replaced, however, there was no change. I'm told the lock & cylinder should be fine if the key is working properly. What ever is causing the problem, has also been draining on my battery when I shut the car off completely and sits for a period of time.
How do you check under the distribution box?
Any thoughts to what is causing both of these problems?
