BEfore you start it. Our oil pumps are self priming, so all you have to do is pull the fuel pump relay and crank the engine to build oil pressure. I however, didn't build any oil pressure at all after 10 minutes of on/off cranking when I installed my 3L. The oil didn't even make it to my oil filter (1st port of call so to say) and so I made a contraption to force oil back to the oil pump (using air pressure from my compressor) to help prime the so called "self priming" oil pump. Then I built up oil pressure after 3 seconds of cranking.
That's weird. I built pressure after about 10 seconds of priming. Well at least you got the job done.
How do you prime your engines with oil after a rebuild, before you start it or when you time the cams?
*Mash* the gas pedal to the floor and hold it there while you turn the key & crank it.
Per Stazi, this is an idiot switch so you don't flood the engine prior to starting.
HTH.
Before you start it. Our oil pumps are self priming, ...
I however, didn't build any oil pressure at all after 10 minutes of on/off cranking when I installed my 3L....
