Results 1 to 8 of 8
Thread: oh no!
    Jun 2006
    Hampstead, Maryland
    1,258
    Default oh no!
    bought the SVT not to long ago and i belive the rack and pinnion needs to be raplced or does it? everytime i start the cars or turn the wheel it makes a really bad whineing noise and it leaks power stearing fluid like a river. Are these symptoms of the rack going bad? or the power stearing pump going bad?
    2001 Ford SVT F150 Lightning Black
    1998 Ford SVT Contour Silver Frost E0 #3455/6535 *sold*
    *lots of contour parts for sale please PM me*
    http://www.contour.org/ceg-vb/showthread.php?t=31994
    Jun 2005
    Virginia, USA
    11,070
    Where is it leaking from?
    "Entiendo un poco espaņol"
    Jun 2006
    Hampstead, Maryland
    1,258
    under the engine
    Jun 2005
    Virginia, USA
    11,070
    Quote Originally Posted by my98SVTturbo View Post
    under the engine
    ROTFL. Clean the bottom pan well and toss some talcuum powder on the pan (bottom and side). Then determine where the leak is coming from.
    Jun 2006
    Hampstead, Maryland
    1,258
    its power stearinf fluid...(from the power stearing pump)
    Jun 2006
    Hampstead, Maryland
    1,258
    im asuming the pump
    Sep 2000
    7,332
    The pump is mounted in the "V" at the upper front of the engine. When it leaks, it is usually from the front seal and it makes the engine timing cover wet.
    You really do need to see where it is leaking from. Power steering hoses don't give much trouble with our cars, but don't go throwing a pump on it if the rack is leaking.
    Jim Johnson
    98 SVT
    03 Escape Limited
    Jun 2006
    Hampstead, Maryland
    1,258
    im getting it looked at within the next week or 2
