Page 4 of 4
FirstFirst ... 2 3 4
Results 31 to 33 of 33
Thread: Rear clunking sound when going over bumps
  1. #31
    Aug 2007
    St. Charles, IL.
    66
    P.S. Anyone want to show a picture of what the're talking about with the end links and such?
    White 96 Mystique LS
    2.5 Duratec ATX
    I will not be a slave to time, time must learn to roll with me.
  2. #32
    Apr 2007
    West NJ
    146
    Quote Originally Posted by Redstar View Post
    While the car is sitting on the ground, try to move that piece where the arrow is pointing from side to side. You cannot jack up one wheel either, its either both rear wheels in the air or on the ground.
  3. #33
    bringing this thread back to life because it came up when i googled my problem.
    got a rattle over any bump on pass/rear. replaced sway bar end links today cuz they looked shot and deff were and didnt fix it. pass side sway bar to frame mount is broke off on one side and half way torn on the other. i also have those bushings on the way. other side mount to frame looks ok. any suggestions on fixing that mount????? reinforced by welding? iv seen aftermarket U braces.
    can anyone elaborate on the struts and strut mounts causing this annoying noise?
Page 4 of 4
