Am I correct in thinking that there is no differance between SVT springs and regular V-6 springs...either height or spring rate wise? I seem to recall that discussion a while back.
The fronts are the same. The rears are the same as any stick shift V6.
Also, the rear struts are the same. The front struts are the same for the E0 but the E1 and later SVT has revalved front struts that keeps the car from lifting as much on acceleration or diving as much on braking.
The sway bars are different.
The stiffest stock struts and springs are from the 95-97 SE.
Jim Johnson
98 SVT
03 Escape Limited
Thanks Big Jim. Going back to stock ride height for the winter.
