Yes 42lb injectors are plenty big enough. A 255lph fuel pump is plenty overkill as well. Just for kicks though, check your fuel pressure as some have stated. Mine is around 47psi at idle, 55 under load, and it even creeps up to 65psi under boost (which Tom accounts for in his tunes).
I had issues with my car running pig rich, then I would mess around with things and it would go so lean I couldn't even drive it out of the driveway. It ended up being my faulty 80mm Lightning MAF. Datalogs didn't show it was faulty either, but I swapped the MAF after weeks of pain and troubleshooting and now she is perfect! Unplug the MAF to put the car in closed loop and if it runs richer by using the tables and ignoring the sensor inputs (o2's, ait, maf). Your MAF may not be the suspect, but I wouldn't overlook it.
My 2 cents.
98.5 T Red SVT #4636/6535 ... SVT cam'd 3L Turbo
Owned 28 SVT's, looking for my 29th. Need SVT Parts? PM me!
PM me for engine/trans/suspension swaps, etc... 3 Liter Swaps done RIGHT!
