+ Reply to Thread
Results 1 to 3 of 3
Thread: Front spring noise
  1. #1
    Default Front spring noise
    Front spring is making sproing noise. It does it usually when i go over a bump or in or out of a rough driveway. I think when i turn the steering wheel the springs are binding on the mounts and then when i go over a bump they sproing back to their normal position. Is there a bushing or something in there that could be worn out that would be making this noise. thanks
  2. #2
    Join Date
    Mar 2007
    Baltimore, MD
    Posts
    194
    Default
    Does the noise sound like metal hitting metal
    1995 Contour 2.5 SE
    TOTALED ON MAY 6,2007
    1996 Contour 2.5 SE
    Born June 2 2007
    Stock
  3. #3
    Default
    no it sounds like a spring popping back to it's relaxed position
+ Reply to Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
