Results 1 to 6 of 6
Thread: intake manifold control runner
  1. Default intake manifold control runner
    my contour 99 se v6 109000miles
    it has been running bad. it bogs/ just revs slow after 4rpms to 6 1/2rmps
    the check engine light came on soo i brought it to auto zone, they hooked there
    meter up to it, it said that the intake manifold runner control was stuck open
    does any one know what this could be
    Thanks
    <font color="red"> 1999 Contour sport ---
    1999 xcsp600 fast [img]/ubbthreads/images/graemlins/smile.gif[/img]---
    Feb 2004
    Somewhere in MO. Bleeding Mercon 5
    1,082
    Quote Originally Posted by contour99freak View Post
    Thanks
    One of two things...Either the IMRC has failed due to excessive heat (very common), or the linkage shaft that opens and closes both banks of secondary butterflies has been broken. If you remove the UIM you can gain access to the secondaries and aforementioned linkage easily. There are two white plastic inserts that retain the linkage rod in place. These get very hot and become brittle over time and will break. This in turn causes the linkage rod to become very sloppy or even fall out of the inserts all together. This will throw the code as well. It causes one of the banks of secondary butterflies to stay open at all times. Removing the UIM is not very difficult. Just do it carefully.
    If you remove the accordian tube and airbox you can actually see underneath the throttle body enough to inspect the linkage rod and inserts without removing the UIM. If that is not the problem, then it will more than likely be the IMRC failure. There is a fix lurking around here somewhere. I'm pretty sure some one brought the link over from the Old Forum. Hope this helps. Keep us posted.
    For reference, the plastic inserts can be had still from Ford at the mere sum of $5.00 a piece. The linkage rod is somewhere around the $7.00 mark if remember correctly.
    Mazda North America Sales (K.C. Mo.)
    Buy Mazdas From me!!! Think: MazdaSpeed
    E0 3l--13's **Parting Out**
    2000 SEVT-- The Pretty Car (Work in further Progress)
    Feb 2006
    Southeast Michigan
    2,997
    Quote Originally Posted by Pale Horse View Post
    The IMRC box fix is only if your resistor went bad. I opened up my IMRC box when I had that code and the same symptoms... my problem was that my cable had actually broke in two inside the IMRC box. I had to replace the whole box and cable which is very easy and doesn't take long at all. But other than that, you had great information!
    Reebs
    98.5 T Red SVT #4636/6535 ... SVT cam'd 3L Turbo
    Owned 28 SVT's, looking for my 29th. Need SVT Parts? PM me!
    PM me for engine/trans/suspension swaps, etc... 3 Liter Swaps done RIGHT!
    Feb 2004
    1,082
    You're right. That can also be one of the problems. I didn't even think about that and it should have been one of the first things to check.
    [troutslap/ ouch]
  5. Default more help
    thanks for the tips
    i have a couple questions is the uim the intake manifold if it is and i take it off will i need to replace the gaskets. also what and were is the IMRC box
    Jun 2005
    Virginia, USA
    11,070
    UIM upper intake manifold. IMRC under plastic water pump cover (three 7mm bolts to remove the plastic cover). If you haven't replaced the gasket for the UIM before, yes, you need a new gasket when you remove the UIM. If you replaced it in the past 6 months or so, you probably don't need a new gasket.
    Edit. Figure 4 in Autozone link for water pump pulley shield.
    http://www.autozone.com/servlet/UiBr...3d801bc4af.jsp
    "Entiendo un poco espaņol"
