Results 1 to 2 of 2
Thread: Duratec Performance - Read First
    Exclamation Duratec Performance - Read First
    Exclamation
    =Exhaust=
    "V8/Mustang sound!"
    No cat-back or custom exhaust will give you that sound - it's a V6. There are options to make a nice sounding exhausts.
    Differing exhaust configurations will create different sound outputs. There are a few choices out there, so we've compiled a database of exhaust sounds.
    EXHAUST SOUND CLIPS
    The SVT exhaust is a single 2.25" to two 2" pipes.
    The SVT resonator is the most restrictive part of the exhaust. A popular modification is to replace the stock SVT resonator with a straight through glasspack or resonator. A popular one is the Magnaflow 10435.
    =Injectors=
    19lb injectors will support 225-240 FWHP (standard on SVTs), which is sufficient for most 2.5s.
    =SVT UIMs=
    Terry Haines confirmed that the UIMs from all model year SVTs are indeed the same. Ford changed the part #s because...who knows.
    The 5 extra horsepower is a result of:
    - later heads being ported, early not
    - later heads have a revised/added intake port hone
    - .25 compression ratio increase in later years
    Rick Miller from Extrude Hone also confirmed that the UIMs from all model year SVTs are the same.
    =Non-SVT Duratec Performance=
    - One of the most popular exhaust modifications for non-SVTs is to bolt on the SVT exhaust. The only modification needed would be to add a hanger.
    - SVT Lower Intake Manifold (LIM)
    - SVT Upper Intake Manifold (UIM)
    - SVT Throttle Body (TB)
    =Differences 2.5L SVT vs. 2.5L non-SVT=
    As posted by CEGer my csvt
    SVT vs SE differences discussion
    SVT specific features, 6th post
    This is lifted from the 99 model year owners guide supplement:
    -larger front brakes, 10.94" vented front rotors
    -bosch 4 channel, 4 sensor antilock braking system
    -enhanced suspension, 19 mm front stabilizer and 18 mm rear stabilzer
    -unique front and rear bumper covers
    -round foglamps
    -unique mesh grills
    -unique rear valance panel, rocker sill extentions, mesh grill and stainless muffler tips
    -unique wheels
    -special seats front and rear with extra bolstering
    -unique texture door trim inserts
    -svt gauges
    Engine:
    -hp=195 for 98 and 200 @6700rpm for 99/00
    -torque=167 lb/ft @5625
    -redline=6750 soft and 7000 hard
    -10.0:1 compression ratio, increased in 2k to i don't remember what
    -throttle body=60mm
    -70 mm mass air sensor
    -large conical airfilter
    -heavy duty radiator
    -extrude honed uim and heads
    -32 mm lim
    -special cams and pistons
    -18 lbs flywheel
    -19 lbs/hr fuel injectors
    -block mounted water to oil oil cooler
    -quasi dual exhaust
    -special clutch
    Search for: se vs svt, engine differences, svt engine features, svt engine, regular duratec vs svt duratec
    2005 GTO IBM - 341hp/341tq
    - Volant intake, JBA catless midpipes, H-pipe, GMM ripshifter, BMR skidplate, HIDs, SAP bumper & grilles, CV8-R taillights
    Local CEGers: If you need detailing PM me
Tags for this Thread
