Looking to buy a 98 Zetec, but there is one problem
Manimillion
Ottawa, Canada
I took a look at a '98 Zetec w/ 171,000km's today. Everything is fine with the car. It needs front bearings and balljoints, other then that there was a CEL, I pulled the code and it was P1381 - Variable Cam Timing Over-advanced (Bank 1). I drove the car and it seems to drive fine, with no hesitation, bucking or misfire through out the rev range.
Should I be staying away from this car? What could be wrong?
Could be a couple of things. First I would change the oil. It could be contaminated oil. If it still comes on after resetting, It could be a timing issue. Don't know when a timing belt was put on last. That engine has a VCT solenoid and if the timing is not perfect it can give that code. The last thing is the VCT solenoid could be bad. With that many miles, I would do a timing belt change and waterpump change. I think the Gates timing kit runs about $100 and the waterpump is probably $40. If the VCT solenoid is bad you can get that from Teamford for about $275.
what are they asking for it and in how good of shape is the rest of the vehicle? i have a customer that has a bad solenoid and she doesnt have the money to fix it so she drives it, doesnt notice that anything is wrong. has plenty of power ect..
