anybody have the front fuse box diagram or in what section to search in the ford cd?
CSVT 98 #1862 of 6535 06/11/1997
3.0,tw8mm,msds-h,2.5exhaust ,optimized y pipe, superchip,original svt cams, unorthodox udp,stage 1 spec clutch,optima yellow battery
GTP 2002 no cat,original intake,mil eliminator,u bend deleted, 9.60 1/8 mille stock
Click on the figures in Autozonelink.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
"Entiendo un poco espaņol"
thanks but i need the wiring diagram , my fuse box is melted and need to replace with a used that i have and need to know where to connect each wire, i the diagram that use the electrical technician to fix this stuff
noup the ford cd i have dont have that is the 98 ford cd only 98 carsnothing for the fuses i have a ford dvd buth is scratched
i remeber i downloaded from a site buth dont find the link
Ok i lied that was for the 95-99 years. Dang it i have googled this wiring diagram and i cant find anything. Anybody know what the fuse is for the cigarette lighter on an 00 stique?
Download the Owners' Manual (free). www.fleet.ford.com
If you're stressing out over the time it takes to remove a FUSE, how do you find time to actually start the car or go anywhere?????
