Does anyone know where to find (or have) detailed specifications concerning the 3L Duratec shortblock?s
What are the specs that you need?![]()
3.0 13.5@104 http://www.youtube.com/watch?v=tisIv-JstmE
NEW 4 bolt control arms $105!
NEW GCK axles $65 each!
PM me for details
well, im doing a full 3L swap but dont plan on using the stock 3L 02 taurus shortblock pistons, crank, etc. I was looking for specs specific stock specs on these parts so I know where to go as far as purchasing aftermarket replacement parts to increase the compression ratio.
Im trying to figure out how to squeeze the most gains out of the engine possible before adding turbo, supercharger, or nitrous.
just get new pistons...cant remember where they are though, someone will chime in. Or instead of a straight 3l drop in, use svt heads and up for raised compression, thats what I would do...
2000 Contour SVT
SF - #542 of 2150
3L: SVT Cams/LIM/UIM/Optimized TB/MAF
HMS Trans: Torsen/SS Forks/Synchros/Zetec FD
Mods: K&N/MSDS Headers/Trubendz Y & Catback/DMD/Steeda Short Throw
Tuning: Xcal2 with PRP
Susp: Bat Euro Kit
Lol well the new pistons part is what im trying to figure out, but i dont know where to start from because I dont know whats better than what I already have since I dont actually know what I already have...(dimensional specification wise)
1) Make a list of the specs you need.
2) Use the search to find what you can. (Don't be lazy, a lot of this has been covered). Don't forget to search the old forum that we just switched from.
3) List out the specific dimensions/specs you still need. Don't be generic and just say you need info.
2002 Ford Taurus
Engine: DOHC 3.0-Liter, 24-Valve, V6, DOHC, Duratec Engine
Compression Ratio: 10.00
Horsepower@RPM 200 hp @5650rpm
Torque Lbs. Per Ft 200@ 4400
Valves per cylinder 4
Bore 3.50
Stroke 3.10
Also read:
http://www.contour.org/ubbthreads/sh...b=5&o=&fpart=1
2000 Contour SVT
SF - #542 of 2150
Susp: Bat Euro Kit
Am I the only person wondering why he wants to UP the C/R, before adding a turbo or supercharger? I can see with nitrous, but definitely not the T/C or S/C!!
Mark
2004 Mazda 6
I don't know what in the world he wants to do...
But that link I posted to the old forums was a sticky on the old forums "piston durability" and I believe it touches on Forced Induction. So needless to say, he better read it.
2000 Contour SVT
SF - #542 of 2150
Susp: Bat Euro Kit
