Page 1 of 6
1 2 3 ... LastLast
Results 1 to 10 of 53
Thread: RWD transmission for Duratec V6?
    Aug 2002
    Salt Lake City, Utah
    5,383
    Default RWD transmission for Duratec V6?
    I'm wondering if anyone knows of a RWD manual transmission the duratec V6 will mate up to? I know of David Godfrey's XR4Ti that has a 3L mated to a T5 (with a one off flywheel and bellhousing adapter plate...), but I'd like to find something that can adapt a bit more easily if I can.
    TIA
    2012 Mustang GT w/ Brembo Pkg
    1965 Buick Skylark GS
    1964 Chevrolet Impala SS
    Sep 2000
    Louisville, Ky
    9,582
    Lincoln LS trans?
    Jim Hahn
    1999 Tropic Green SVT Contour
    364 whp, 410 wtq @ 4,700 rpm
    RX7 TT trannies work, at least on a Miata.
    http://www.miata.net/news/v6.html
    2013 Dodge Dart 1.4T/6mt
    Viper powered project with father
    99SE traded in 04/13
    Aug 2002
    5,383
    Yeah, the 3L MT would work. I'll have to see how much power they can handle.
    The RX7 trans had to be adpated. I'm looking for a straight across fitment with no mods or next to none.
    Aug 2002
    Genoa City WI
    1,152
    Awesome, finally not a new guy coming on the forum and asking what V-12 twin turbo engine and AWD drive train can I add to my se contour.
    Good luck
    2000 Black SVT with 114k Build # 1598 1\14\2000 Parting Out
    1998 SE with 99K Daily Driver
    98.5 Black SVT with 47k miles Build #5683 Born on 4\15\1998 crashed... fixing
    2002 Jeep Wrangler X 3" lift with 33 by 12.5
    Sep 2000
    Westland, MI
    5,335
    I'm pretty sure for it to be a direct bolt-up to the LS trans, you need to have the LS/S-type block.
    I think whatever you want to use, will require a custom bellhousing or intermediate plate to allow things to bolt together.
    Aug 2002
    5,383
    I should be able to use the getrag 221 used by the LS/S-type. It shares the same pressure plate as the x-type, but they use different clutches.
    I came across a guy who's converting an x-type to RWD, and it mated up to his 3L. Not 100% on X-types sharing the same bellhousing pattern as the Duratec V6's Contiques use. The 221 needs to be built to handle any decent power, but they do have upgrades that are available.
    Hopefully I hear back from Godfrey about his sources to make the goodies to use a T5.....
    What is this going into anyway? The first rwd tour or what?
  9. #9
    Aug 2002
    5,383
    Not sure yet really. Once I can mate a 3L to a good RWD transmission, I can go from there
  10. #10
    Someone on NECO had found the AWD "transfer case" from the Euro Mondeo and it shows our trans have all the holes and such to bolt it up. Of course I can't find the thread right now, because the forums are STILL down over there.
    1999 Black Mercury Cougar V6 MTX "Sonic" - Future HPDE/Time Attack machine
    1999 Silver Mercury Cougar V6 MTX "Silver" - Future Summer Daily Driver
    1989 White Jeep Cherokee I6 4x4 "Tails" - Winter Daily Driver/Off-road adventuremobile
Page 1 of 6
1 2 3 ... LastLast
