Swirl removal with my PC..
I've looked at numerous videos and read a lot of threads regarding it.... but it comes down to this...
Do I use a yellow pad with a medium compound or an orange pad with a medium - heavy compound as my every day basic swirl remover for a car that probably has 30 to 50k miles of wear on it's paint?
I recommend starting out with the orange. If that doesn't get you the results you want then switch to the yellow. The yellow is the more aggressive pad and they say if you use it to follow up with the orange afterward.
Have you seen the two videos at the link listed below? Scroll about halfway down the page.
http://www.autogeek.net/poca74pofcop.html
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
