Results 1 to 5 of 5
Thread: water pump
    Default water pump
    how involved is this this project? how many shop hours?
    Mar 2004
    Louisivlle Ky
    6,934
    i did it myself in about 6hrs. i also went to school for auto tech. its really not that hard to do. how many miles are on the car and when was the last time the timing belt was changed? you may want to consider changing it while youve got it apart depending on the answer to those.
    TZT Performance http://www.tztperformance.com/
    officially a troll. '93 3000GT VR4 #2229/2595
    '00 Black SVTC #391 - sold 5/1/10
    '97 GL Turbo Zetec - gone
    for a water pump it does look a bit invloved, but I guess i get to kill a flock of birds with one stone.
    Timing belt, pullies, tensioner
    Septine belt, and belt tensioner, idler pully
    Get to replace a bad lifter
    plugs
    bad valve cover gasket
    water pump
    noticed that the brake pads where a bit thin too,
    bright side is, the motor mount looks good
    Jan 2005
    Escondido, CA
    19
    Remove the sep belt to gain access. The water pump bolts on to the block with 3 bolts. The pulley needs to be removed also which is another 3 bolts. Everything else is simple bolt off and on but is hard due to the limited space of the inner fender.
    Mark J. Covill
    Jul 2003
    Graham, TX: a place so nice, they rob your house twice! & Houma, LA
    3,073
    There is actually a fair amount of space in there, once you get the engine mount, coolant reservoir, and timing crap out of the way.
    • See, you think I give a ••••. Wrong. In fact, while you talk, I'm thinking, "How can I give less of a ••••?" That's why I look interested.
    • I know there's a god, because every once in a while someone whispers in my ear, "You're my favorite!"
