Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 21
Thread: Shift Cable Repair
    Aug 2004
    Ocala, Florida
    193
    Default Shift Cable Repair
    I recently found out my shift cable end was missing the bushing that secured it to the trans as shown in picture 1. My shifter had alot of play in it, and made engaging gears sometimes difficult. I received a helpful tip from another CEG'er to use some 5/16" washers (I used a total of 3) and a metal retaining clip to secure it. I also found some stiff rubber hose and cut it to length to fit snuggly inside of the plastic shift cable end. This eliminated all of the play, see picture 2. All said and done, this fix works wonders. My shifter feels great again, without any slack. I guess I could have bought the new bushings from ford and swapped them over, but this seems to work just as well. Total cost = $5.00
    1.
    2.
    98 Black CSVT, #2386 of 6535
    Sep 2000
    7,295
    Thanks for sharing. Necessity is the mother of invention. That looks like as good of a repair can be found.
    Jim Johnson
    98 SVT
    03 Escape Limited
    10 Fusion Sport
    Sep 2004
    Columbia South Carolina
    51
    Default I posted in a reply to another thread
    I posted in a reply to another thread but I had an extra set of sway bar end link bushings laying around and cut one down to fit * side to side shift cable * and there is no play there either I used a plastic epoxy some of the 5 minute stuff which made it stick to the inside of the plastic sleeve pretty well, since the inside diameter was a tight fit I secured the outside with two zip strips worked like a charm for me. May do the front to back section tomorrow even though it doesn't look or feel to bad.
    99 SVT #341
    03 Vert GT triple black combo w/Roush kit-traded in on a 06 honda accord
    03 Hemi Ram-traded with accord in on an 07 Ridgeline.
    84 Mustang SVO
    88 Turbocoupe
    May 2000
    Grand Rapids, MI
    26,530
    Blog Entries
    1
    It will work until you get a new end link. Still too much play IMO.
    Former owner of '98 SVT #1,173. Need a 95-00 Ford CD manual? PM me
    Jan 2005
    Sandwich, Massachusetts
    701
    if you look straight down from the brake fluid resivour, will you see this bolt?
    #1119
    Custom interior
    17" Excel Maj's Gunmetal
    15% Tint
    3L Escape 3.0 20k
    Xcal 3 from nautilus performance
    MSDS headers
    trubendz 3" test pipe with Magnaflow Cat
    cherry bomb resonator
    knauberized
    hightowers w/ eyelids
    stazi g2 grilles
    May 2002
    Albany, Georgia
    22,648
    I just got a new cable end. I think my dealer wanted $13 and I talked him down to $10. I think bill jenkins has them for like $7.
    2011 Hyundai Accent
    Sold: 98.5 SVT-187whp
    96 ATX Zetec-Scrapped after 2 wrecks
    FS: $100 off $200 or more SPEC purchase
    May 2002
    Albany, Georgia
    22,648
    Quote Originally Posted by S2Knott View Post
    Can't say for sure without looking, and my car isn't with me right now, but I don't think you can, too much stuff above it. Just take the wheel off.
    2011 Hyundai Accent
    Oct 2007
    Charlottesville
    301
    my shift cable bushing broke off tonight and left me stranded and unable to get into gear so I found a washer and used a zip tie. No problems since.
  9. #9
    Sep 2000
    7,295
    Don't consider the zip tie as anything other than temporary.
    Jim Johnson
    98 SVT
    03 Escape Limited
    10 Fusion Sport
  10. #10
    I have been having the same prob with my most recent CSVT till today. Got it up in the air and work and sure enough that first pic in this thread was what I had. I actally made a new bushing kinda sorta with a old fuel line discconect and some rubber tape around it. Slid right into place and with a Cotter pin on the end I'm back to good as new. No 2 inches of front to back shifter play anymore!
    99 T-Red CSVT #2300-Sold
    94 Cobra 5.0-Sold
    99 Black CSVT #2200-Sold...
    http://www.cardomain.com/ride/2528810
Page 1 of 3
1 2 3 LastLast
