Results 1 to 8 of 8
Thread: 12v Source
    Apr 2005
    Aliso Viejo, CA
    1,284
    Default 12v Source
    I'm running a few peripherals in the interior (shift light, etc) and I was wondering what the best source of 12v ACC power is? I'd rather not jam a wire into a fuse opening, and I can't run a line straight from the battery (it needs to be ignition-based), so where should I tap?
    Thanks!
    '98 #3780
    Quote Originally Posted by blu_fuz View Post
    I want your tool...... how much for that?
    Jun 2006
    Toronto (Woodbridge)
    822
    if you have a sunroof, that's the best place to start, because it's wired to the ignition coil, just crimp and either solder or just electrical tape it.
    2002 Volvo S40 1.9T
    1998 Mercury Mystique LS (Written Off)
    Dec 2001
    Gales Ferry, CT
    24,469
    Blog Entries
    93
    ignition switch ...
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 2k Contour SVT - #2137
    Apr 2005
    Aliso Viejo, CA
    1,284
    Your logic baffles me. Lol.
    What color wire is the main ignition, or should I tap it all the way up near the key? And M4gician, where did you tap the sunroof wire?
    '98 #3780
    Dec 2001
    Gales Ferry, CT
    24,469
    Blog Entries
    93
    Quote Originally Posted by Matty K View Post
    iirc red ... hot all the time, but I don't recall off hand, yes I would pick that up in the column
    at the sunroof, or any circuit get a test light and find one that is hot when the ignition is on and that is the one that you want
    - 12 Focus SE
    Apr 2005
    Aliso Viejo, CA
    1,284
    The, uh, the car has no power right now, as most of it is in pieces. Hence why I'm wiring it up now. Thanks guys, lemme see what I can find.
    '98 #3780
    Sep 2006
    Portland, Orygun
    1,685
    Do you have the layout of the fuse panel? The Power Moon Roof wire is purple / black and it is in place in the connector (most likely it was in my 95) wether you have a Moon Roof or not. I found it on top of the interior fuse panel in connector #298 pin#8. This is coming from the Power window fuse #21 / 40 amp. You may want to put an inline fuse on your tap wire with a lower amp rating in order to supply proper protection to what ever you are installing. There are several other wires that can be used depending on what options you have, or don't have would be better put.
    I would strongly suggest if you don't have the ford cd. You can get one from ebay it has been an immense help to me in adding options that detroit forgot to install like power windows, seats, fog lights, power antenna, and heated mirrors to mention a few. The cd covers the mechanical and service aspects too.
    Hope this helps......
    Proud Dad of a US Marine
    99 Contour SE Sport / V6 MTX
    95 Contour GL / 4banger ATX - Like no other.
    "its not shot it just grinds a little when going into third" - tjzollman 2/25/08
    Try to be as good a person, as your dog thinks you are....
    May 2004
    Calgary, Alberta, Canada
    4,437
    Run a relay off your battery and Ignition wire off the steering Colum.
    It runs off the starter IIRC and its PURE GREEN. Thats where i wired my wideband into. Works great.
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
