Results 1 to 5 of 5
Thread: can you clean the egr valve?
    Oct 2003
    Prunedale, California
    1,612
    Default can you clean the egr valve?
    im getting a code say my egr valve is stuck closed.
    1995 Contour GL Zetec with 116k miles.
    1999 Ford Contour SE Zetec with 145k miles.
    AIM Name: ContourAlf
    Yahoo IM: Contour_Freak
    WANTED...
    7 spoke SE rim center caps for a 95. PM me if you got one.
    Sep 2002
    St. Louis, MO
    2,831
    There is no such code that says that. EGR valves rarely fail anyway.
    Start over. Take the fault code and plug it into the SEARCH tool to see if there are previous conversations about it. Ask for help on anything you don't understand.
    Most EGR codes (95%+) on Contours result from either clogged throttle body ports or bad DPFE sensors.
    Steve
    Owner's manual for 1996 and newer are available to download from www.fleet.ford.com under MAINTENANCE tab.
    98 Contour SE Sport 2.5 Duratec ATX - 197K
    2001 F250 Super Duty 6.8L 4x4 - The NEW Workhorse 152K.
    2007 Mariner 3.0L AWD - Wifey's new ride.
    Mar 2003
    West Palm Beach, FL
    8,062
    Quote Originally Posted by projectSHO89 View Post
    The Zetec engines are not equipped with an EGR valve are they?? They also don't generally suffer from the clogged EGR passeges problem.
    I'd like to know specifically what code you got on one of your Zetecs, contourfreak22...
    I have wondered at times what the Ten Commandments would have looked like
    if Moses had run them through the US Congress.
    Oct 2003
    1,612
    there is an egr valve. i pulled one out at work. also i saw it in the engine bay.
    WANTED...
    The 1995 through 1997 Zetecs have an EGR valve. 1998+ uses the VCT system instead.
    When I started getting codes on my 1996 Zetec indicating trouble with the EGR valve, I took the valve out and cleaned it up as well as I possibly could. This solved the problem for a few months, then it came back again. I figured that as much trouble as it was to get the valve out and back, I wasn't going to go through all that again just to clean the old one. Second time, I bought a new EGR valve, and installed it. That was several years ago, and I haven't had any trouble with it since then. I think I paid about $80 back then for the new EGR valve.
    Hyster E60XM-33
    1996 Mystique GS, Zetec, ATX — Totaled in a collision on 26 Oct 2009
    1997 Contour GL, Duratec, ATX, “Sport Package” — Successor to the dead Mystique
    To email me, remove the string HatesSpam from this address:BobHatesSpam@Blaylock.to
