View Poll Results: How much would you spend for a Tru duals setup?
Voters
34. You may not vote on this poll
  • $400-499
    22 64.71%
  • $500-599
    6 17.65%
  • $600-699
    3 8.82%
  • $700-799
    0 0%
  • $800+ Pretty much money no object
    3 8.82%
Page 1 of 6
1 2 3 ... LastLast
Results 1 to 10 of 55
Thread: Skunkworks Autosport Tru Duals Interest check
    Aug 2002
    the 248
    11,141
    Default Skunkworks Autosport Tru Duals Interest check
    http://www.contour.org/ceg-vb/showthread.php?t=11186
    The link to the group buy
    How much would you want to spend on a tru dual exhuast setup for the contour?
    You would have a few options as far as mufflers,resonators, cats and tips, also options as far as 2" or 2.25" piping. This would be for under the gas tank as pictured. Obviously if you wanted a H pipe it would be more as well as certain other features. All the bends would be mandel not crush bends.
    Could possibly work out something so that it bolts to the back of the Nautilus Performance down pipe for the turbo kit to make use of the 2 2" pipes.
    Remember this is a true dual kit that will show up at your door that you can bolt on yourself. Not have to take it to a muffler shop. No other company is offering anything even in the same neighborhood as this.
    Many CEG'rs have paid over $1200 for custom true duals. Obviously I should state that this would be for offroad use only, especially if you where to go without cats.
    Off the top of my head these are the company's that i would deal with.
    Spintech
    Vibrant
    Thermal
    Magnaflow
    Dynomax
    Dr. Gas
    Alright I have priced everything out and this is what you would get.
    An Aluminized 2" tru duals with flex pipes, all mandel bends, the pipes to connect to the exhuast manifolds/headers, Spintech or Thermal mufflers and choice of tips. It will show up and all you have to do is bolt it up to the manifolds, put on 2 exhuast clamps(or have it welded) and hang the exhuast.
    You choice of tips
    http://www.thermalrd.com/tips.htm
    http://vibrantperformance.com/catalo...38fd78287c77cc
    $650 plus shipping
    If you want to add on parts heres the prices
    Cats $180 for vibrant High flow ceramic cats
    H pipe $100
    Resonators depends on model wanted
    Extra bungs $25 dollars per bung
    Different mufflers? If you want Different mufflers remove $125 from the price then add the cost of the ones you want.
    Full Stainless steel exhuast? I can get cost put its probably gonna be cost to double
    Attenion!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Disclaimer: This dual exhuast passes under the gas tank. Skunkworks Autosport and Myself are not liable for imporperly installed exhuast systems. There should be a heatsheild installed to minimize the amount of heat that is transfered to the gas tank area. Improperly installed exhuast systems can lead to melted gas tanks and a fire hazard. If Skunkworks Autosport feels that you do not have the mechanical apptitude to install this exhuast it will not be sold to you.
    Pictures:
    Video is of a 2" Tru dual with 2 18" magnaflow resonators and 2 spintech mufflers
    Tru Duals with Magnaflow:
    Last edited by Steeda...; 04-19-2007 at 10:26 PM. Reason: Added disclaimer 4/17/2007
    May 2006
    Glen Ellyn, IL
    2,452
    no H-pipe?
    -JON 99 CSVT T-Red. #2437
    www.myspace.com/ripscottfrost
  3. Default
    Also H pipe is not necessary, and the dominant portion of duals do not have an H or X pipe
    US23
    May 2006
    Glen Ellyn, IL
    2,452
    nvm i did not read the whole post
    Jun 2005
    Pennsylvania
    2,227
    I like the idea but the video has some rasp/backfiring or something going on. Is this correctable or is this typical for true duals?
    -Justin
    Pittsburgh - City of Champions...again
    Steelers & Penguins 2009 Champs
    May 2006
    Glen Ellyn, IL
    2,452
    Quote Originally Posted by teamSVTour View Post
    when i get out of gear i get lots of pops. sounds neat to me. its the trubendz not my car backfiring.
    Aug 2002
    the 248
    11,141
    Mufflers where brand new. When you hear it fire thats the first time they where ever on.
    My full magnaflow doesn't pop and isn't raspy at all but IMHO the spintechs are a deeper tone and smoother. In the video the exhuast ended around the gas tank and the mufflers where just slipped on so the popping could be cuased by air entering back into the system under deacceleration. I can take a video of the current setup if its not snowing tomorrow. There is a difference between the stock and Tru dual setup as far as seat of pants power goes. My SVT made 165hp and 144tq at the wheels and with 4 people in the car it felt faster than it ever did with 1 or 2 people in. IM trying to figure out a time to go get it dyno'd but not sure when it will be
    Oct 2005
    Toledo
    1,188
    I don't mind the popping but I'm not a fan of the rasp at all. I'm interested to hear what your full magnaflows sounds like
    If these are cheap enough I just might need to get them. I need money
    TRed CSVT on FSVTs.. in pieces for now!
    http://www.cardomain.com/ride/2154233
  9. #9
    May 2006
    New Brunswick, NJ
    462
    i'm looking to get an aftermarket exhaust setup for my CSVT this summer. BUt i'm kind of clueless about this stuff. What exactly are the advantages of true duels as compared to say the truebendz cat-backs?
    hp? tone?
    2000 Contour SVT in Silver Frost #1633 of 2150
    K&N open-air intake / JVC head unit / pioneer 4-ways / polk momo sub / knauberized / drilled and slotted rotors/ 17" Rev Model-X wheels/ tinted tails/ SilFro painted mesh/ Dynomax glasspack/ short shifter
  10. #10
    Aug 2002
    the 248
    11,141
    As stated its not as raspy as the video points out. It was also brand new and not warmed up.
    Advantages:
    Tru duals will flow more air than the trubendz
    More muffler options
    It will be built on my car soo you know it is going to fit
    Disadvantages:
    It takes time to order the parts/build it(can't really make a jig when everyone wants diff stuff)
    expensive shipping
