Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 27
Thread: To you F/I guys...
    Feb 2006
    Southeast Michigan
    3,001
    Default To you F/I guys...
    I figured I would post this question in F/I, because you guys are the ones who I need the advice from. I just about to drop in my 3L turbo, and I plan to have between 310hp and 350hp depending on what I set my boost controller to.
    I have a stage 2 made of kevlar (not stage 2+) and spec's website says that it is good for 340 ft.lbs/torque. I will be right around maxing that thing out, but I am not sure if they under rate the clutches or whatnot. My spec stage 2 also has around 20,000 miles of moderate n/a driving on it. I know it has life left, but I am afraid to put this beast together and find out that the clutch is slipping under boost.
    What clutches are you guys running, and what power do you think/know that your clutch can hold? I know it is just another expense, but I think it would be worth it for me to pick up another clutch. I also don't know what to do about resurfacing, because I have a fidanza LW flywheel.
    Well, go ahead and give me some advice! My SVT will be driven a ton, so I need a clutch that will have a decent life expectancy.
    Thanks,
    Jeff
    98.5 T Red SVT #4636/6535 ... SVT cam'd 3L Turbo
    Owned 28 SVT's, looking for my 29th. Need SVT Parts? PM me!
    PM me for engine/trans/suspension swaps, etc... 3 Liter Swaps done RIGHT!
    Aug 2003
    DFW (Keller, TX)
    2,487
    get a hold of SVTcuervo and just get a new disc (stage 3) and put it in there...It's like 160 or so. totally worth not pulling it apart again.
    98 SVT # 692 05/02/97 3L turbo....SOLD!!!
    DD: 2005 Honda Civic 39.7mpg (best so far)
    Wife's car: E53 X5
    garage: E39 M5
    call spec and ask them.
    My project website
    Sep 2000
    Louisville, Ky
    9,578
    SPEC Stage 3 here. Its very on/off type of clutch so taking off from a stop is something you have to get used to. Mine has seen as much as 410 foot pounds of tq. It sees about 350 wtq daily.
    Jim Hahn
    1999 Tropic Green SVT Contour
    364 whp, 410 wtq @ 4,700 rpm
  5. Default
    Im hoping that my stage 3 does not suck as hard as Ive heard. I like being able to manipulate the clutch.
    I will also toss this question in here. Im in the same boat as Reebs, I had planned on picking up a beater car for next winter, but that is probably not in the cards.
    How much of a pain in the ass am I in for using this as a DD year round? Anythoughts on limiting boost in the colder months, or any other precautions I should take during the winter?
    US23
    Mar 2003
    West Palm Beach, FL
    8,063
    A stage 3 in snow?
    Carry snow shoes in the trunk.
    But seriously, I know nothing about this - I was just bein' a funny guy...
  7. Default
    Eh, I may be safe. I should graduate in dec. so the bulk of my last semester should be snow free, and for the bad days I can steal the girlfriends car
    US23
    Feb 2006
    Southeast Michigan
    3,001
    Quote Originally Posted by stilov View Post
    I don't think that you can mix the stage 2 pressure plate with the stage 3 disc, can you?!?!?
  9. #9
    Quote Originally Posted by Reebs View Post
    Answer is yes, it wont be an issue! But make sure everything is perfectly flat to avoid engagement issues.
    Personally, if you have the money I would go with a stage 3+. Its a full faced carbon/semimetallic clutch that uses a stage 5 pressure plate. She's good for 540hp. Compared to the stage 3, it is significantly better on drivability and has much less of an on/off feeling.
    I ordered the 3+ for those reasons!
    Customized Millennium Body Kit, Preditor Hood, Z3 fenders, CC Short Throw
    Trubendz SS Dual Exit w/Magnaflow
    3.0L build up start date: 1-26-07
    NPG Stage 3 Turbo Kit
    " Project cars are never finished! "
  10. #10
    Feb 2006
    Southeast Michigan
    3,001
    I just tried to call spec, but they are closed for the day. I believe that SVTCuervo said you can't mix match all the clutches and pressure plates like you are making it sound, however, I will be talking with the spec tech in the morning to find out for sure. Stage 3+ clutch sounds like it would be perfect for me, but it sure is pricey! It costs more than stage 4 and 5 too!
    I know that clutches are rated by torque at the crank, so Tom, knowing my setup what do you think I'll be putting out at the crank!?! I'll have your stage 2 turbo kit with the garrett turbo on a stock 3L with SVT cams... oh, and at 7.5 - 10psi!
