Results 1 to 10 of 10
Thread: Amp power up problem
    May 2004
    Coon Rapids, MN
    2,883
    Default Amp power up problem
    I have this Clarion Amp 2/1 Channel, Model APA2103, that I lent to my brother to use in his SVT Focus last summer. He gave it back to me just a few months ago telling me that it wasn't working.
    I hooked it up to my system and sure enough it would power up and then shut off right away. Has anyone run into this before? No bad connections, no bad fuses, I'm at a loss. I opened up the amp to see if anything was fried inside and everything appears to be normal. Any ideas would be greatly appreciated as I would like to put some small subs in my car. Thanks.
    -Mike
    98 Contour SVT Toreador Red- #49/6535 DOB 3/25/97,178.88whp/157.78ftlbs, Follow my 3L/turbo build here... link
    85 Camaro-1969 350ci, 503BHP
    Aug 2005
    Trois-Rivieres, Quebec
    1,106
    did you check the REM from your H.U ?
    08 Subaru Impreza WRX 5Dr - WR Blue Mica
    98.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
    RU-3530/CTA Intake, MSDS Headers/Y-Pipe, Magnaflow#10435, SPEC Stage 1/Flywheel, DMD, UD Alt&P/S Pulley, Optimized TB, B&M...
    HERE
    May 2004
    Coon Rapids, MN
    2,883
    I didn't even use the REM, I just ran a 12v signal from the power wire.
    -Mike
    Aug 2005
    1,106
    so how do you turn of your amp ? you have a switch ?
    HERE
    May 2004
    Coon Rapids, MN
    2,883
    No I just hooked it up that way to test it.
    -Mike
    Apr 2005
    Pillaging in Freedom, PA.
    3,875
    Could it be too much, IIRC the REM is a small amount of power, maybe it's overloading it? Just a guess.
    Scott,
    1999 CSVT, Tropic Green, #2068
    "And that was all without even a single drop of rum" -Captain Jack Sparrow.
    If I'm a moderator, why don't I have groupies!?!
    Jan 2002
    Grand Blanc, MI
    3,486
    Quote Originally Posted by getsum111 View Post
    Its not the REM wire, remember his brother had the same problem with the REM wire and he had it hooked up normally, the 12v hook up was just for testing. And you can run 12v to the REM without a problem.
    To me it sounds like it is going into protect mode. Sounds like something might be loose or crossed internally causing a short.
    2000 SVT Black/Tan #1163/2150 SOLD
    2008 Grand Prix GXP
    2009 Saturn Vue Redline V6 AWD.
    May 2004
    Coon Rapids, MN
    2,883
    Yea I thought this too, which is why I took it apart. Everything looks fine. If there was a short there would most likely be a charred spot on the mounting surface or somewhere on the board... which I didn't see. So unless there's an open somewhere. Only way to check that is to look at the resistance in the wires, which would take a long, long time.
    -Mike
  9. #9
    Power supply or output transiter (MOSFET) took a poopy and sometimes you cant see them go bad. Not every amp releases that magical smoke when it goes bad, get yourself a new can of amp smoke and you'll be back in the game
  10. #10
    May 2004
    Coon Rapids, MN
    2,883
    Quote Originally Posted by KnuKonceptz View Post
    If that was the case would it still power up briefly like it does? I would imagine if the power supply took a crap it wouldn't even turn on.
    -Mike
