EDIT:
Alright this is my attempt to summarize to date what has gone on and build a Table of Contents so to speak out of a 'Build Spec' list. I will come back to this point periodically to update this section so that everyone can have one place to go to answer their questions hopefully.
Engine
05 Ford Escape 3L Short Block - modified to have oil squirters Post#526, Page 14
K1 Technologies Rods - Post#130, page 4
Diamond Racing Pistons (~9.6:1) - Post#371, Page 10
2005 Escape 3L Cylinder Heads - Stage II, BPE Racing Heads Post#648, Page 17
Mountune Valve Springs - Post#667, Page 17
Mountune Cams - Post#704, Page 18
PowerSeal Lifters - Post#772, Page 20
05 Mondeo ST220 UIM - Post#41, Page 2
05 Escape LIM
SCT Big Bore 90mm BA-2400 MAF
Fuel System
05 Escape Fuel Rail - Link to thread on brazing fuel rail
Injector Dynamics 1000cc injectors ID1000.60.14
Aeromotive 13101 A1000 Fuel Pressure Regulator
Aeromotive 11142 340 Stealth Pump (x2)
Ignition
Accel Super Coil w/MSD DIS 4 - Post #189, Page 5
Talyor 8.2mm Thundervolt Wires
Exhaust
WeaponR Stainless Steel Headers
Borla Stainless Steel Cat-back - modified to have 3" pipe from down pipe to muffler split
Porsche GT3 Quad stainless steel tips - Post#74, Page 2
Turbocharger Setup
NPG Racing kit - Will be only using portions of it
Turbocharger - Garret A/R .63
Intercooler - Still investigating air-air or water-air
HKS EVC6 Mappable Boost Controller - Post #166, page 5
Transmission
2002 Mercury Cougar MTX-75 - Built by HMS
3.54 08 Focus Final Drive
Upgraded Ford Shift Forks
Keyed HMS Contour Shift Tower
Torsen T2 ATB differential
ClutchNet 6 puck clutch disk
ClutchNet Red Pressure Plate
Ford TOB
DSS Level 3.9 Axle & Hub kit - Post#980, Page 25
Interior
Mondeo Trip Computer - Post#308, Page 8
Corbeau FX1 Pro Seats
Lotek triple gauge pod with faze gauges
Innovate Motorsports LC-1 wideband gauge
Exterior
HoK Shimrin Designer Pearl - Trublue, Post#1053, Page 27, Repaint - Post#1177, Page 30
RP Carbon Fiber Hood
RP Carbon Fiber Pre98 Trunk
Carbon Fiber roof overlay
RP projector head lights
RP projector tail lights
Brakes
Baer Track-Plus brake kit - 330mm cross drilled and slotted rotors w/ dual piston calipers
NPG Rear adaptor kit - 278mm cross drilled and slotted rotors w/ single piston OEM rear calipers
stainless steel braided lines
Suspension
BAT Euro struts/springs
RP RSTB
RP FSTB
RP Traction Bars
PRT Rear Fore LCA - Post#1591, Page 40
PRT Rear Aft LCA - Post#1591, Page 40
ADDCO Rear Sway Bar - Post#1321, Page 34
Wheels/Tires
SSW Trex 17x7 wheels
BF Goodrich G-Force KDW 225/45/ZR17 - Street
Nitto NT01 tires 235/40/ZR17 - Track
Misc Parts, which will not be used
Mondeo ST220 LIM - Dimensionally the same as Escape LIM, but made of aluminum, will hold in more heat may change mind if more air flow is needed as this could be ported. Post#286, Page 8
Misc Part/Tool Pics
Fel-Pro Gasket Sets - Post #442, Page 12
Specialty tools for piston/rod/crank assembly - Post#443, Page 12
Ford Rotunda Kits - Post#497, Page 13
Roll of Carbon Fiber - Post#513, Page 13
Build Progress:
Exterior Tear Down - Post#263, Page 7
Engine Pull - Perfectly running SVT 2.5L sent to stand Post#350, Page 9 & Post#408, Page 11
Interior Gutted - Post#381, Page 10
Piston & Rod Assembly - Post#448, Page 12
Cylinder Head Disassembly - Post#500, Page 13
Cylinder Head Cleaning/Bead Blasting - Post#532, Page 14
Cylinder Head Flow Chart - Post#612, Page 16
Cam Discussions - Post#641, Page 17
Cylinder Head Assembly - Post#736, Page 19
Roll Resistor Prep Work - Post#767, Page 20
Paint Arrival - Post#783, Page 20
Engine Bay Cleared - Post#788, Page 20
Fuel pump removal and comparison of OEM and Aeromotive Stealth pumps - Post#973, Page 25
Paint prep begins - Post#892, page 23
Paint prep and sealer work - Post#994, page 25
So as some of you know I recently bought one of NPG's turbo kits and I have now decided to install a 3L as well at the same time. This thread will serve as my build thread with pictures of the entire process from the tear down of the car and the teardown/build/install of the 3L and turbo kit. Here is the build plan and the starting pictures.
2005 Ford Escape 3.0L Duratec, 43k miles, compression test of 207psi
-parts to be ordered/installed (as of right now, investigating options with Scat, Wiseco, and ROSS)
K1 rods
4.6L valves
-parts on order
waiting for my ST220 UIM to arrive from the UK and then it's being sent out for EH
http://img215.imageshack.us/img215/4...cape110109.jpg
http://img267.imageshack.us/img267/2...ape1101092.jpg
Also for those interested all of my original parts will be for sale (since there is nothing wrong with my current 2.5L) at some point in the classifieds. I will also post in here as parts become available.
