hylix
If using the FSVT calipers and brackets, I understand I'll need a couple shims to center the rotor in the caliper. Where are you guys getting these shims?
Are these the correct dimensions for the shims/washers/spacers?:
ID-12mm OD-25mm T-2.2~3mm (ID-31/64", OD-1", T-~3/32")
Why I want to use FSVT calipers:
I had a front caliper seize on my '00 SE. I figure I may as well replace the calipers and brackets with the FSVT gear (or at least, the CSVT gear).
FSVT Part numbers for front calipers w/bracket:
A-1 CARDONE Part # 18B4846
A-1 CARDONE Part # 18B4847
CSVT Part numbers for front calipers, w/bracket:
A-1 CARDONE Part # 18B4622B
A-1 CARDONE Part # 18B4623B
Of course using the FSVT rotors and ceramic pads as well, (or CSVT, if I choose that route).
I don't want to do the warmonger/NPG kit because I need new a caliper(s). If I'm looking to save the cash, I'll just buy a set of CSVT calipers with brackets from rock auto (and proper pads/rotors). and have at least a slight upgrade from stock.
