Dyoel182
If you havent done the stainless steel brake hoses I fully recommend them to help with a soft feeling pedal. You should only notice extra softness if you switch to the focus caliper with the bigger piston.
done them and it didnt change the feel much if any. maybe a little firmer but the travel is still the same as before, and its too much in my opinion. I know the amount of travel it has is normal, i, like Rara, like less travel with more bite.If you havent done the stainless steel brake hoses I fully recommend them to help with a soft feeling pedal. You should only notice extra softness if you switch to the focus caliper with the bigger piston.
I still think the biggest difference is because my pre98 didnt have ABS and the SVT does. every car i have driven with ABS seems to have a softer pedal with more travel than the version without ABS. :shrug:
I agree, the SVT has too much pedal travel for my liking. i much preferred the travel of my pre98, very little travel before the brakes started to bite. that being said, the only difference between the systems is the SVT has ABS which adds to amount of fluid that needs to be moved.
ive been debating on upgrading to the 300mm brakes but was always concerned about making the pedal softer, which since i think its too soft already, would be a problem. Short of removing the ABS, any good way to shorten the pedal travel?
you're going to have to trust me, its not the ABS. When the ABS valves are closed (ie, any time you aren't in a panic stop) it acts as a straight through passage, pretty much just like a plain brake tube.
Did your GL have drum brakes in the rear?
Also one more thing to check is the pushrod in the power booster. Its been a while since I have had a Contour master cylinder off but the pushrod may have an adjustment that would decrease the pedal travel. With somebody in the car, remove the bolts holding the MC to the booster, relieve vacuum in the booster and have the person press the pedal down very slowly while you hold the MC noting how much pedal travel it takes before the MC is pushed off the booster. If there is an adjustment it will be right at the end of the pushrod and you will need to do very fine adjustments because if you go too far it can apply pressure to the brakes all the time.
