Bumping this instead of started a new thread.
Planning on doing my relocation here in the next week or two and throwing around some ideas in my head. I'm moving the battery to the trunk (obviously), on the passenger side, right behind the seat. I've already made a false floor for extra support under my sub box, and golf bag, so Ill be mounting it to the section of false floor that stays stationary 99% of the time. I have a good bit of KnuKonceptz 1/0 gauge wire for power. I also have a KnuKonceptz 3 way distribution block I'm planning on placing inside the car, somewhat different from what seems to be the normal setup I've seen on here. I am going to be doing the "big 3" at the same time of the relocation , so I figure that when making the new cables for the alternator and starter, I can redirect them to the inside, instead of to the factory location. I don't like the look of whats left of the normal battery relocation setups with all the wiring running to the now open space of what was once the battery.
So I plan to run the cable inside the car, down the passenger side (hopefully finding a existing hole or space to create a new one) into the foot well near the ecu. Create the new cables for the alternator to d-block, and starter to d-block, as well as extend the wires from the fuse box to the passenger side to be ran with the other two. With creating a new cable for the alternator, it will remove the mega fuse from inline with the wire, to now in the d-block.
Anyone see any issues with these ideas? I know it may seem like more than necessary to complete the job, but from what I picture in my head, it will come out clean and work well.
