T Hudson Jr
am i going to need a special adapter to go from the factory wiring to my aftermarket head unit (Alpine CDA-7490)
Reading over the how-to about the factory harness...
Wouldn't you want to get access to the input to the factory amp to bypass it rather than the out put? If you take the plug from the output and disconnect from the source, it would no longer be active. Then connecting your wires to a non active set of wires is useless.
Unless it some how transfers back somehow. I'll pull the schematic (sp?). But any input would be great to clarify.
oh...okay, thanks. am i going to need an adapter then????
