AGrayson84
Hi everyone, I'm looking for some upgraded Contour SVT sway bars, new or used. If you have anything let me know please!
-Andrew
-Andrew
I already the factory anti-sway bars...
Thanks B3NN3TT... I didn't know the factory front SVT sway bar was the best option for the front... I appreciate the heads-up!
Your car has a BAT rear bar and boxed in subframe already.... ?
EDIT: I should say that it did have one installed at one point and AFAIK it was never removed.
I had a Roush rear sway bar (21mm) along with the larger Cougar front sway bar when I started autocrossing this car. Eventually I got hold of a smaller SVT Contour front bar and swapped it in, and the difference was really night and day. It really balanced the chassis right out and got rid of much of my understeer problems. I can still get it to push when applying power in a turn, but not at all like before.
I'd say the ONLY reason to EVER go with a larger front sway bar is if you install some kind of ungodly ludicrous rear sway bar, like a 24mm Aussie unit or something, and can't keep the rear end in line anymore.
Echo the above, a larger front bar will give you more mid-corner and corner exit traction issues, the understeer that B3NN3TT mentions. A slightly larger rear bar will make the car more "entertaining", easier to pivot the rear in autocross.
The anti-roll bar mounts on the rear subframes of these cars are known weak spots, even the factory bars will fracture the mounts. Seeing as how you live in the salt belt, you might want to consider one of these with your larger rear bar.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=321189866401
Last Updated: 7/20/22
