YOOOO
I have a Kicker 10" L5 subwoofer in a very nice enclosed box paired with an Eclipse XA1000 amplifier.
$250 + shipping
local pick up preferred
Description: A Kicker enclosed 10" Solobaric L5 Enclosed in a Kicker box.
10" subwoofer with dual 4-ohm voice coils
SoloKon aluminum-treated composite cone with Santoprene surround
rigid steel basket
power range: 50-450 RMS watts (225 watts per voice coil)
peak power: 900 watts
frequency response: 24-100 Hz
sensitivity: 86.5 dB
mounting depth: 6-1/16"
sealed box volume: 0.66-1.0 cubic feet
ported box volume: 1.25-2.25 cu. ft.
XA Series 1-Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 320 watts x 1 chan.
2 ohms: 480 watts x 1 chan.
Max power output: 640 watts x 1 chan.
LED clipping indicator
Tuned Bass EQ (0-8 dB bass boost)
Attractive design for practicality and ease of use with all controls such as level, crossover, low frequency boost and high/low pass filter adjustments mounted on the top panel
Output terminals conveniently located to allow multiple in-line unit installations
Very high efficiency rate with low current draw
Gold-plated screw terminals
Variable low-pass filter (50-500 Hz, 18 dB/octave)
Subsonic Filter (18 dB at 18 Hz)
CEA-2006 compliant amplifier
Frequency response: 20-20000 Hz
Dimensions: 9-13/16"L x 10-3/16"W x 2-5/16"H
$250 + shipping
rigid steel basket
RMS Power Rating:
