How to fit a glasspack?
Guitarman19853
Pittsburgh, Pa
Was looking under the car last night at the resonator. I know glasspacks are popular to replace the resonator but looking at it it seems that the Contour needs an offset inlet muffler for the resonator. Fitting a glasspack looks like it needs some custom fabrication to mount it at an angle.
IF you do a search for mufflers like at Summit you will find glass packs with offset/angled pipes at both ends. I don't remember what angle I usedto line up the pipes but I know that I found a glass pack that fit perfect! Each end lined up with the pipes, I only had to use an a pipe size adaptor to fit it up to the stock pipes.
