xjustinx
So my csvt threw some codes and I took it to my local shop and this is what was diganosed:
datalog EEC, fuel trims are pegging opposite. LTFT's are off by 20%. Unknown cause will require more diganoistics. All data points to bad O2 sensors but it could be an electrical issue.
So I took the car back and started to change the O2 sensors myself. Front one was no problem to get out. Back one not so easy. To make a long story short ended up having to take the header out to remove O2 sensor cause some one jb welded it in So I have to tap the hole then I will be good to go. What I was wondering was I have MSDS headers and Y-pipe. A cat is connected right behind the Y-pipe. But the sensors are on the header and Y-pipe. Would I be throwing codes cause I need Mil eliminators???
