3L rebuild questions...
captastic
Ok...I have 2 3L engines I'm gonna be rebuilding in the next 3-4 months. I'd like some input on the first, and I'll post another topic when I do the other.
Description:
​Unknown year 3L block with 2000 SVT heads/UIM/LIM (True old school hybrid)
>100,000 miles
EGR Delete (welded shut)
​Engine was originally put together by former CEG member Cory in WV. Engine was data-logged and tuned. Runs great and didn't burn any oil. I'm pulling the engine and its going into another SVT I just purchased, so I'm gonna rebuild it for the new car. This will be my 3 season fun car. NO TRACKING (I have another SVT I'm prepping for track time). I'm gonna keep the true hybrid format, as it works for the street.
​Parts I'm buying:
Clevite main and rod bearings
ARP Head studs (cheaper than the stock TTY Ford head bolts I believe)
All new gaskets
Rings
​New crank and camshaft sensors
Maybe new timing gear?
​I plan on having the heads and block hot tanked, and then the block honed.
Since this is gonna be a street build, I wasn't planning on head work (porting, 5 angle valve job, or 3L valves and all), tho I was planning on gasket matching and all.
Will I need new:
Pistons?
Lifters?
Valve springs?
​Timing gear?
​Valves?
Valve guides?
​Do I need forged Pistons and Rods for a relatively mild street build?
​I already have MSDS headers, Weapon R y-pipe, and true Borla exhaust. Of course I'll replace the alternator while the motor is out. Prob a Clutchnet Stage 1 clutch. I believe it has the stock SVT clutch. Maybe grab a DMD.
​Any advice or expertise would be appreciated.
i would recommend checking the lifters. they have a spring inside a think. and some of them "squish" when you squeeze them with your fingers. i had 2 sets replaced all the loose ones and ive never had an idle valve tick after that.
i would recommend a port and polish. i max port and polished my heads and gained 22 tq and 17 hp. but i also upgraded to st220 manifolds at the same time.
and honestly i wouldnt recommend replacing the bearings. my 70k factory rod bearing had such minimal wear. i replaced them with clevite and spun a rod within like 10k.
thats kind of all the insight i can give you. i dont know how much money you want to spend or what your intentions are. its different for every situtation
.... if you can find one;
a lightened flywheel makes the rev's much more snappy.
I put one on when I bought the DMD.... worked well.... took a couple of days to stop stalling the car at the lights :blush: ......G.
Yeah I’m kind of in the same situation right now. I have a 3l from my old contour that is in working condition and want to put on my SVT but idk if I should rebuild the whole thing (new bearings, rings, timing chain?) etc. or just put new gaskets in and call it good. Anyone else have any opinions about this? I won’t be tracking it but I do plan on “spirited” driving and maybe the getting into autocross. Don’t mean to highjack the thread, but I think we both have the same questions.
