Has anyone found an off the shelf solution for no code with 3.0L TB? The range is way off.
iirc the SVT was 440 to 3.8k ohms and Taurus was 380 to 3.2k so the stock 3.0L tps will throw a code eventually, and this is a daily driver for a friend and needs to run with no codes.
This tps spins the other way than 95% of most Ford ones do so I havent gone to the parts store yet with a pigtail and meter to find one that will work yet.
Anyone found a solution? I can swap the TB with another one I have and use the SVT TPS but I would rather just throw on a TPS.
